AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Blast from the past...
2 REPLIES 2
Allen_Hart
359 Views, 2 Replies
I have a few part models that I made back in May of 2000 using Mechanical Desktop, release 3 maybe?  I need to migrate these files to a more current version that I can at least measure using Autocad or Inventor in order to re-create them.  Since they open up as only proxy objects I cant snap to anything to measure them. Inventor won't convert them since they are pre-MDT6 files.  HELP!  can someone tell me what my options are?
thanks, Allen
2 REPLIES 2
Allen_Hart
in reply to: Allen_Hart
I have discovered that although Inventor will not import the MDT models it will open them and allow measuring of line lengths and distance between lines.  This should give me what I need for now.
Allen
JDMather
AutoCAD Mechanical is not MDT.
What version of Inventor are you running?
Have you downloaded MDT 2009?
”Boost
