AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Autocrat mechanical 2014 transmission sprockets
6 REPLIES 6
558 Views, 6 Replies
In the Tab Content I don't have transmission sprockets . Why ? Is it possible to get it ?
Thank you
Siva
6 REPLIES 6
michaelsu
Hi Siva,
Could you let me know which particular sprocket and its detail is missing?
I can help log a wish item in our issue tracking system. Currently we only have supported few sprockets from some standards.
Also, have you tried to create them using custom content feature?
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
in reply to: michaelsu
Hi
sorry I was not available for the last week..
I don't have a specific sprocket yet, I was looking for the general idea of how to chose one .
But I see it is not available, will it be ? Some time soon...
Thank for your time
Siva
michaelsu
Hi Siva,
You can use command AMSPROCKET or go to content tab in the ribbon ->Calculation Panel->Click dropdown for Chains/Belts, then you will see Sprocket/Pulley. After you click it, a wizard will pop up to enable you to choose a sprocket.
Let me know if you have further concerns.
Thanks.
Michael Su
SQA Engineer
Hi
This I know , but there is only chain sprockets and pulleys, what about transmission and gear box?
Thank you
sivan
michaelsu
Hi Sivan,
Unfortunately AutoCAD Mechanical doesn't have all various types of content or standard from various industries.
Instead, we provide a feature to publish your own custom content so you will be able to define a content you use daily and then insert them like normal AutoCAD Mechanical content.
To learn more about custom content, please refer to help link below.
http://docs.autodesk.com/AMECH_PP/2014/ENU/files/GUID-F8C57125-CAF9-47E7-B877-5EB8F26FFD12.htm
Thanks.
Michael Su
SQA Engineer
Thank you I do that..
sivan
”Boost
