Hi All,
I am new to the board and i wasn't able to find the functionality that i was looking for online.
Is anyone aware of any converter software that can monitor a windows directory and automatically convert cad drawings to pdf as soon as there is a new drawing or an existing drawing gets updated ?
I appriciate your help.
A software that can monitor a directory for dwg files and once someone publishes a copy into that specific folder, software would automagically convert it to PDF. I am trying to eliminate the human step of manually converting dwgs to pdf.
I know what you're asking for, and no - I'm not aware of anything commercial that will do the trick. There's a few stumbling blocks along the way, e.g. needing to be able to call a session of AutoCAD or other software which can both open and print a drawing, which will automatically have access to the correct paths for CTB/STB files, PC3s, SHX references, XREFs, and so on.
It could be possible with a session of AutoCAD running on a spare computer with a simple DOS box program that monitors a folder (or folders), and opens a session for each file found. But there's a fair amount of programming needed to pull it off consistently.
Out of the box there *is* the option to automatically create DWF files as users work on the sources files. But that imposes a bit of a speed penalty. The DWF files could then be routed elsewhere on an overnight basis for conversion to PDF if desired, since they are a little more automation-friendly.
I am using Auto CAD electrical 2013. I am not sure, if that has the capability. ANyway, I will try and will update you.
Thanks for the info.
