AutoCAD Mechanical 2014 - using a drawing with Inventor views (3) from 2 different .ipt files. Nothing shows in external references, yet we know the files are 'linked'. the problem is when I go to check in the files I get this error:
--------------------------- Vault Add-in --------------------------- Could not check in. Unable to reload xrefs after file relocation.
--------------------------- OK ---------------------------"
This problem only exists with drawing that have inventor views. Nothing has been 'relocated', no 'xrefs' are present. This file has no problem checking in with AutoCAD Mechanical 2013.
Unfortunately working with the file in 2014 (mech) creates a slightly incompatible version with 2013, disabling Mechanical commands (even if I didn't add any mechanical objects). Then when you check it in, it forces it to Mechanical 2013 (from ACAD Mech 2013), likely misconverting things along the way.
Can anybody confirm this, or have a fix for this?
jvj
Hello jvj,
Does it happen to any simple ipt and drawing views, like a solid and a base view drawing?
If possible, can you please send the ipt files and drawings you created in 2014 for further look? My email address is zhiyuan.su@autodesk.com
Attempt to check in with 2013 Mechanical into ADMS 2014. Then check out with ACAD Mechanical 2014.
The problem has not persisted as of yet.
Hello Jamie,
As for the models and drawings you sent to me, when I open the drawings and found the drawing views are with red border which means it is unresolved and cannot find the model for which it was created. I tried it happened in both 2013 and 2014 when open them. If I created drawing views from scratch, there was no problem.
When you checkin the drawings, you need to make sure those drawing views are not unresolved. In the help, there's a FAQ item about unresolved inventor reference file which may give you a clue why it happend.
When files referenced by an Inventor model are not found automatically, drawing views derived from this model are said to contain unresolved file references.
A drawing view can contain unresolved file references for any of the following reasons.
For cases 1 and 2, use Autodesk Inventor to update the project file to specify the current location of the files that are not found automatically.
For case 3, use the VIEWSETPROJ command to select the correct project file as the active project file.
Hope it helps.
