Hi All,
AutoCAD Mechanical 2011 Update 1 is released on Live Update.
It is also available in AutoCAD Mechanical Services & Support site.
thank you,
Eng Seng
Since installation, there are commands that do not work properly
Texts do not, Cancel button is no longer, drawing frame, etc, delete command is probably only the 2nd Times open, etc.
Greetings
Michael Berger
how do I run plain autoCAD on AutoCAD Mechanical? I need to just run AutoCAD? Please help.
you can start AutoCAD vanilla from Start Menu.
Start menu >> All Programs >> Autodesk >> AutoCAD Mechanical 2011 >> AutoCAD 2011
Tommy Guo
AutoCAD Mechanical SQA
Since updating to Service Pack 1 we have been getting an "Unable to locate path information file" notice when starting ACADM 2012. See attached image. After clicking the close button twice ACADM 2012 will start.
I have installed the update.
But still I get " ; error: VLISP: internal: Document application(.VLX) not found" error message whenever I open a dwg through a hyperlink and when that drawing is closed after some edit, there is no prompt to save the file. Have not noticed anything else yet.
This thread is one of my favourite threads on here, i totally love autocad mechanical, because as a mechanical engineer it really makes life and work easy to do, cheers guys
