AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
AutoCAD Mechanical 2010_AM commands not working
1 REPLY 1
604 Views, 1 Reply
Any time I try to use a command that begins with AM autoCAD tells me the command does not exist. Things like fillet, offset, and angular dimension. If I use the regular command for them they work fine. This is only commands in Ribbon. Most of the commands have an alternative, but things like Detail do not.
1 REPLY 1
cheewec
i guess you are still running AutoCAD instead of AutoCAD Mechanical.
You may need to repair you installation, then check you shorcut properties as "C:\Program Files\Autodesk\ACADM 2010\acad.exe"  /p <<ACADMPP>>
* ACADMPP is mechanical profile
”Boost
