AutoCAD Mechanical General
TITOPERON4108
Message 1 of 3 (319 Views)
AutoCAD Mech 2012 and 2013 corrupted files
319 Views, 2 Replies
05-07-2012 11:26 AM
I have 2 files attached that I can not recover within Autocad Mechanical. I have already tried on AutoCAD Mechanical 2012 and 2013, but both showed me the same issues:
"01505770 crash 19-04-2012.dwg" >> this file crashed AutoCAD imediately when openning
"01505770 CANNOT ADD DIMENSIONS AND COPYCLIP CONTENT.dwg" >> this file does not allow dimension creation, copyclip (CTRL+C) and I cannot correctly insert correct parts list with filter by part on some layouts.
Please someone could check this out?
Dimitri
Product Support
Matt.Desfosses
Message 2 of 3 (261 Views)
Re: AutoCAD Mech 2012 and 2013 corrupted files
05-14-2012 06:45 AM in reply to: TITOPERON4108
The file that you could not put any dimensions in was corrupt in the template.  Once I inserted it into a new template I was able to put dimensions.  The other file I was not able to recover.
Matt Desfosses
Support Specialist
Product Support
TITOPERON4108
Message 3 of 3 (234 Views)
05-17-2012 05:53 AM in reply to: Matt.Desfosses
Thanks Matt,
Yes, it is an abnormal situation that I would like Autodesk to avoid. The software cannot crash if the file is corrupted and the commands should work even if it is corrupted. Specially if you see simpler applications like Intelicad opening these files and operating them without any problem.
I would like to hear from Autodesk if it is going to be fixed some day.
Regards
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
