AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Arc dimension
1 REPLY 1
Roger_Block
243 Views, 1 Reply
Arc dimension
How can I get rid of the little arc that appears when you use the arc dimension feature.
1 REPLY 1
In your Properties brower, you can turn off the 'Ext Line' option for a single elimination. To get rid of all of them, in your Dimension Style Manager, choose Radial, then Modify, then lines tab, then suppress Ext line 1.
I hope that helps.
”Boost
