AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
Annotative Power Dimensions problems
4 REPLIES 4
schnautza
704 Views, 4 Replies
I've set up my dimensions to be annotative with 3/32" text and 3/32" arrows.
I've got my annotation scale set as 1/2" = 1'-0"
When I draw a dimension with AMPOWERDIM (the default dimension button), my resulting text and dimensions are 3/64", half of the size that they should be.
When I draw a dimension with DIMLINEAR, it is scaled correctly.
My dimstyle is "3I Standard" and there is a sub-dimstyle "Linear".
Both of these are set up as annotative.
If I go to Properties of one of the AMPOWERDIM dimensions, the dimstyle says "3I Standard$0". If I switch that to "3I Standard", then it scales correctly.
In Properties, under "Fit>>Dim Scale Overall", the AMPOWERDIM shows "0" and the DIMLINEAR shows "12".
What is going on? How do I make the power dims act like everything else? Am I missing a variable somewhere?
4 REPLIES 4
schnautza
in reply to: schnautza
Oh, and I failed to mention, I am working in modelspace in AutoCAD Mechanical 2014.
steve216586
See last post in this thread concerning AMSCAREA command: http://forums.autodesk.com/t5/AutoCAD-Mechanical/Dimensions-ignoring-dimscale/td-p/4380271
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
schnautza
in reply to: steve216586
That didn't do anything.
michaelsu
I see similar problem in another post I replied. Hope it helps.
http://forums.autodesk.com/t5/AutoCAD-Mechanical/annotative-power-dimension/m-p/3358825/highlight/tr...
Let me know if you have more concerns.
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
”Boost
