While opening the AutoCAD file which I have, I am gettinbg the error as shown in the Snapshot.
Please reply as sson as possible its urgent...
It is just a warning message telling you that Annotation scaling does NOT support mechanical objects in AutoCAD Mechanical, like symbols, content, power dimension, etc. AutoCAD objects will behave the same as they are in AutoCAD when you change annotation scaling. So Annotation scaling is just a AutoCAD feature that should be used with the above in mind when use it in AutoCAD Mechanical.
See the other similar post for more detail.
Michael Su,
Do you know how to fix this issue, every new drawing i open now gives me this error. Also when copying & pasting from a model to layout the scale of my objects are much bigger than before. Please Help. Thanks
