I'm using Autocad Mechanical 2013 and Autodesk Vault Pro 2013.
I have a bunch of .dwg's without visualization files.
the 'update visualization file' always returns an 'unknown publishing error'. So I'm trying to write a script with the AMSCRIPT generator and a custom lisp.
After checking in the first file (successfully, apparently), I consistently get a fatal error. I don't see any evidence that the script made it to the next file.
Here's my code:
(DEFUN Test701upd1 (/)
(COMMAND-S "_PURGE" "B" "*" "N")
(COMMAND-S "_ZOOM" "E")
(COMMAND "QSAVE")
(IF (> (LENGTH (LAYOUTLIST)) 1)
(COMMAND "-VLTCHECKIN" "L" "Y" "L" "")
(COMMAND "-VLTCHECKIN" "L" "Y" "M" "")
And the script:
_.redraw
(load "C:/Users/awatt/Documents/Test701upd1.lsp")
(if Test701upd1-start (Test701upd1-start))
_open
"C:/Vault Workspace/Engineering/701/701-007000/701-7483.dwg"
_.redraw
(Test701upd1)
(command "_.point" (getvar "limmin"))
(command "_.erase" (entlast) "")
_.close
_y
_open
"C:/Vault Workspace/Engineering/701/701-007000/701-7484.dwg"
_.redraw
(Test701upd1)
_.close
_y
_open
"C:/Vault Workspace/Engineering/701/701-007000/701-7488.dwg"
_.redraw
(if Test701upd1-last (Test701upd1-last) (Test701upd1))
_.close
_y
Solved by awatt. Go to Solution.
Thanks to Wayne Brill for the e-mail answer. Next time I'll try the prompt suppression.
I found another work-around that got the job done. I added a COMMAND "CLOSE" to my lisp, and used MS Word to take the save and close sequence out of the script via the 'replace all' tool. That worked for about 99% of my files (literally thousands), though variations would stop the script. But a RESUME kept it moving along, and the few leftovers were easily cleaned up manually.
