Hi...
I use AutoCad Mechanical 2014, now.
While using ACM2010, I was able to draw the construction lines by entering the relative coordinate.
1. Execute [amconstlines]
2. Draw a perpendicular line in arbitrary positions
3. Input [@1000,0]
4. I could draw a new construction line in the position distant 1000 in the direction of X.
But I can't do same operation, now.
The second construction line is drawn by the completely wrong position if the same operation is carried out.
It seems that the above-mentioned operation doesn't correspond from ACM2012.
If You know any informations, can you tell me how I can draw the construction lines by instructing the direction of coordinate on the ACM 2014?
Misean (M.Kawasaki)
