AutoCAD Mechanical Forum
Welcome to Autodesk’s AutoCAD Mechanical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Mechanical topics.
ACAD 2013 Mechanical NO INVENTOR LINK?
7 REPLIES 7
Message 1 of 8
Todzilla60
863 Views, 7 Replies
Does anyone know how to enable "Inventor Link" in ACAD 2013 mech? This "model documentation" is BS.....
7 REPLIES 7
Message 2 of 8
michaelsu
in reply to: Todzilla60
By default, Inventor link feature is not installed by default.
You can go to Control Panel -> Programs and features -> Double click AutoCAD Mehcanical 2013 and Select add/remove features -> Check Autodesk Inventor link
Thanks.
Michael Su
SQA Engineer
Please mark any response as "Accept as Solution" if it answers your question.
Message 3 of 8
Todzilla60
in reply to: michaelsu
Thanks Michael, i dont know why i didnt think of that....
Message 4 of 8
donb
Hi Michael,
Is there any way to break the link ?
I some times need to edit the part but not the model.
donb
donb
Message 5 of 8
cheewec
in reply to: donb
You have your Inventor Application installed, must be same version as the inventor part or newer.
Double-click the root icon in mechanical browser to launch inventor for editing.
Message 6 of 8
lwyles
I’ve followed the above, to get the link to work, but I’m unable to get it to work. I’ve restarted the computer & everything. Is there something else that’s required to make the link work??
Message 7 of 8
lwyles
In addition to my comment above , in the ‘ribbon’ part of the screen the ‘Create View’ > ‘Base’ is missing. Is that a menu-load?? To get that?
Message 8 of 8
michaelsu
in reply to: lwyles
I guess you refer to commands for creating model documentation drawing views. Can you use CUILOAD and try to load ModelDoc.cuix file from the path below if you use win7?
C:\Users\admin\AppData\Roaming\Autodesk\AutoCAD Mechanical 2013 - English\R19.0\enu\Support
Thanks.
Michael Su
SQA Engineer
”Boost
