I have atached the file I'm working on. Could any one help me? I am trying to make this a solid (that is .25" thick) do I have to make it a surface before I can make it a solid? If so how is that done?
Thank you for your help!
Nolie Scheid
Autocad Mecanical 2013
Inventor Pro 2013
Windows 7 64 bit
Solved by Davarn-Tool&Die. Go to Solution.
In AutoCad Mechanical, I would turn the 3 closed shapes into polylines using the pedit or bpoly commands and then the Extrude command directly into a solid.
