• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    why must I regen to display linetypes?
    128 Views, 2 Replies
    12-05-2011 11:26 AM
    Attached is a drawing containing a big rectangular lwpolyline and two relatively small lwpolylines near the drawing origin. One of these smaller plines is on a layer that has a dashed linetype assocated with it. That layer is also red. When I zoom in on that pline, however, I won't see the dashes unless or until a regen occurs. As of this writing, after trying a few things, I'm almost resigned to including a note telling the client they might have to REGEN in order to see non-continuous linetypes display properly. Any ideas?
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: why must I regen to display linetypes?
    12-06-2011 12:11 AM in reply to: tom_brabant
    I guess 'cause your LTSCALE is too low: check the attached file out.
    12-07-2011 07:38 AM in reply to: tom_brabant
    When I open the drawing in the zip file you attached, I get the same behaviour as  the drawing I posted. When I zoom in on the red line, it appears continuous. Once I regen, it appears dashed, as it should. Do you experience something else? I am using release 2010.
