• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    viewport is blank when creating a raster image
    131 Views, 1 Replies
    06-29-2012 11:10 AM
    I am using MAP3D 2013 and trying to create a raster image file for use in anther document (the document will not accept a dwg or dwf file, only a raster image).
    When I use the JPGOUT (or PNGOUT or BMPOUT or TIFOUT) command I can select all of the objects and viewport; there is no problem creating the file.  But when I open up the raster image, only the viewport outline and objects in paperspace have come accross; the viewport appears empty.
    In MAP, the viewport is turned on and I can see everything as intended.
    Any suggestions?
    Alicia
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: viewport is blank when creating a raster image
    06-30-2012 04:39 AM in reply to: amm30165
    1] _PLOTTERMANAGER
    2] add the TIFF UNCOMPRESSED device
    3] plot to file by means of that virtual printer
