• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    using expression builder to list the distance between points
    193 Views, 4 Replies
    05-03-2012 04:57 PM
    Hello. I have a data table showing points surrounding a central source.
    I would like to create a calculation that adds a column in my data table of the points; that shows the distance between each respective point, and the central point.
    My knowledge in expression building is limited, and Im hoping someone here could help me.
    I assume I would be using some form of calculation using the geom, and the X and Y locations, however Im coming up with nada.
    Can anyone help?
    Thanking you in advance
    Colin
    Please use plain text.
    Re: using expression builder to list the distance between points
    05-04-2012 11:46 AM in reply to: COLINBIBLE4464
    I don't believe you can connect 2 features in a calculation. Therefore you want be able to calculate the distance between. That's what lines are for :smileywink:
    How many points are we talking?
    Valued Mentor
    05-04-2012 02:02 PM in reply to: tjmapper
    sqrt (x^2 + y^2) = the dist on a 2d plane
    if origin is 0,0
    then
     Sqrt ( Power (  X1 , 2 )  +  Power (  (Y1, 2 ))
    so subract x & y of your central point from x1 and y1 of each point
    ie origin at 1,1
     Sqrt ( Power ( ( X1-1) , 2 )  +  Power (  (Y1-1) , 2 ))
    dave
    Valued Mentor
    05-04-2012 02:06 PM in reply to: parkr4st
    example i used  UTM83-19 coord sys.  look at the data table. I think this is what you are looking for.
    Dave
    05-06-2012 05:34 PM in reply to: parkr4st
    Thank you guys.
    That was the type of solution that I was looking to implement.
    I have 20 points (residences) surrounding a potential site.
    I was just measuring the distance from the centre of the proposed site ( a coordinate), to each residence (nodes surrounding the proposed site)
    I was writing the distances down and adding them to a spreadsheet. I wanted to shortcut that by having the distances automatically update in the data table if I moved a node (residence). Then I would export the data table into the spreadsheet.
    Colin
