• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    nik.mazreen
    Accepted Solution
    .str format data
    536 Views, 3 Replies
    03-14-2012 02:43 AM
    is there any way to work with string file (.str) from autocad map 3d?any fdo provider support this type of format data?
    thx in advanced..
    -nik-
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: .str format data
    03-14-2012 02:54 AM in reply to: nik.mazreen
    Which of the following ones do you refer to..?
    http://www.fileinfo.com/extension/str
    Product Support
    03-14-2012 12:48 PM in reply to: nik.mazreen
    Not directly, I think.  You might look at Safe to see if they have it listed: http://www.safe.com/fme/format-search/ .  Otherwise, exporting from the source in a more common format will be the best option.
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
    Valued Contributor
    nik.mazreen
    03-14-2012 05:57 PM in reply to: NateMoore
    thx for the reply..
    actually this string file (.str) is created from the software called GEMCOM SURPAC.
    i think you are right, i guess the best way to read this format in map 3d is to convert it to common format.
