• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    split polygon
    205 Views, 5 Replies
    11-14-2012 09:10 PM
    Does anyone know how to split polygon?
    I am using "bpoly" function when I split the polygon but It's unconvenient
    Do you guys know better way to split polygons?
    ps. I go over the functions through help desk.
    Please use plain text.
    Valued Contributor
    Re: split polygon
    11-15-2012 09:43 AM in reply to: lee2mk
    Try the command "mpsplit".  You should be able to select the polygon to split, then draw a line where you want the split to be made (or select an existing line), and it will split it into two new polygons.  It will also give you the option to copy over data from the original polygon to the new ones.
    Norm
    Re: split polygon
    11-15-2012 11:36 PM in reply to: lee2mk
    Hi is there any way how to split FDO Polygons?
    Martin
    Re: split polygon
    11-16-2012 02:08 AM in reply to: maherich
    command _MAPFEATURESPLIT (>>>details<<<)
    - alfred -
    Alfred NESWADBA
    Re: split polygon
    11-16-2012 02:16 AM in reply to: alfred.neswadba
    I placed a wrong question. FDO works but I actualy wanted to ask how to split the industry model objects. I know that in some industry models there are special functions to do that. But I did not found any generell that would work for all of the objects of the geometry type.
    The only way I know is to extract the geometry process it and attach the geometry beck to industry model object.
    Any other hints?
    antoniovinci
    Re: split polygon
    11-16-2012 02:28 AM in reply to: nwray
    Sounds like the OP's not using Mpolygons, sir.
    If the polyline to split is closed, first he would transform it with the _MPOLYGON command (working on circles too).
    By the way, in my Map2006 the existing splitting line must be a Lwpolyline, while simple lines don't work.
