AutoCAD Map 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
select attribute or object data values
Options
- Highlight
- Email to a Friend
267 Views, 3 Replies
09-02-2004 07:18 AM
I've just upgraded from Map 6 to Map 3D. In Map 6, I use Quick Select to search & select blocks based on values in block attributes, and to search & select objects based on values in object data fields. In Map 3D, Quick Select doesn't show any attributes or object data fields, so there's no way to select. This occurs on 3 different licenses of Map 3D, two with a "ToolPac" add-on, and one plain vanilla. I checked one AutoCAD LT 2005 seat, and its Quick Select doesn't show block attributes either. Has anyone else noticed this, and if so, do you have any work-around? The only thing I've been able to do is open a blank drawing and use the Query command to do the search and select.
*Murph
Re: select attribute or object data values
Options
- Highlight
- Email to a Friend
09-02-2004 08:15 AM in reply to:
coalprpmapper
Using the "Find" command with the zoom to option will allow you to select
the blocks with attributtes value. In oder to have the quick select to work
with OD values you have to use "Feature Classifications". Beware though
feature classes can slow down the search.
Murph
"Don Soper" wrote in message
news:10792497.1094134723559.JavaMail.jive@jiveforu m2.autodesk.com...
Options
- Highlight
- Email to a Friend
09-03-2004 11:28 AM in reply to:
coalprpmapper
Already tried Find. Some of my block attributes are "invisible". Find won't zoom to invisible attributes or attributes/text on off/frozen layers.
Say there are 14 blocks named "AA" with invisible attribute "M" containing the value "xyxy". With Map 6, I'd quick select on all blocks AA, then narrow it down to look for attribute M = xyxy (or M wildcard match *xyx*). On OK, all 14 blocks would be SELECTed at once, allowing me to immediately do something with those 14 items (change color, layer, size, wblock etc). Find doesn't "select" anything, just zooms to the location of its current "found" item. I'd have to activate Find 14 times, to find all 14 instances of "xyxy", and that assumes that "xyxy" isn't in some other text item or attribute other than "M". Easier to open a new drawing and do a Query.
Any idea why Autodesk got rid of the quick select's ability to see block attributes and object data fields in the currently open drawing?
*Murph
Options
- Highlight
- Email to a Friend
09-03-2004 11:52 AM in reply to:
coalprpmapper
My guess would be the changes had to do with the newer file format. I think
the data for the ojbect data is stored different in 2004 and 2005 than the
earlier versions.
Murph
news:10825804.1094236152301.JavaMail.jive@jiveforu m2.autodesk.com...
