• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    refresh layer
    136 Views, 2 Replies
    06-21-2012 11:20 AM
    When I am editing my shape file, I select "new feature from geometry" and check in that feature. Sometimes after the "check in", when I refresh layer, the older edits disappear. Any input on what is happening?
    Please use plain text.
    Re: refresh layer
    06-21-2012 12:30 PM in reply to: dkent
    I've seen that if there were multiple connections built to that SHP-data. So e.g. you have connected to the SHP twice and you edit it (one of the multiple connected data), the update of the geometry-data is not refreshed in both connections.
    Another option may be that you have an IDX-file that was modified or created from an ESRI-product. Map3D and ArcGIS handle the IDX different, so exchanging data may result in some defects.
    HTH, - alfred -
    Alfred NESWADBA
    Member
    Re: refresh layer
    06-28-2012 04:11 PM in reply to: dkent
    The refresh layer seems to be regenall for GIS layers.
