• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    ColNew
    Accepted Solution
    polygon centroid problem
    560 Views, 4 Replies
    02-22-2011 09:28 AM
    Hi all,
    I have several mpolygons, that i want to query and bring some object data as well (as text). The problem is that when the centroid of the mpolygon is outside the outline, my text inserts outside, too. Is there a way to insert them "inside" the polygon? Many thanks in advance!
    Please use plain text.
    Distinguished Mentor
    braudpat
    Re: polygon centroid problem
    02-26-2011 07:50 AM in reply to: ColNew
    Hi from France
    I haven't any MAP or CIVIL avallable during WE but
    there is a special ADE command (since the first ADE module with ACAD R13/R12)
    which is called :  ADETEXTLOC   ( Automatic repeat command )
    So you have to use it on every MPolygon, closed Pline where the centroid seems to be outside
    ADETEXTLOC will create a special XDATA which is in fact the "future" LABELPOINT
    which will be used in your future query with properties alteration and text creation
    (for example: .AREA , .LENGTH , .LAYER , or any Object Data Value)
    Do you see what I mean ? I can't help you more without MAP/CIVIL running ...
    Good Luck, Patrice
    ColNew
    02-26-2011 11:01 AM in reply to: braudpat
    Patrice, that worked perfectly! the only problem is that I have too many polygons that I can't handle one by one. It would be perfect for my project (and my boss : | ) if there was an automatic way of indicating the new labelpoints, I'll stick to that solution however, for now! I salute France! Greetings from bankrupt Greece!
    Colin
    braudpat
    01-24-2013 02:13 AM in reply to: ColNew
    Hello
    For your problem, I am working like this ...
    Command: MULTIPLE
    Command to repeat: ADETEXTLOC
    CLIC
    and then Next object ...
    <ESC> <ESC> to stop the repeated command ADETEXTLOC !
    Sorry I don't konow how for exmaple a Lisp/VLisp routien could be better / faster !?
    Bye, Patrice
    *Expert Elite*
    antoniovinci
    02-07-2013 10:30 PM in reply to: braudpat
    I think there's no way to automatize the ADETEXTLOC process on many polygons at once, just because every closed object needs a new position clicked by hand.
    Moreover, the ADETEXTLOC command doesn't know if a centroid lies inside or outside a polygon...
    Merci beaucoup, monsieur.
