• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Murph
    Re: osnap pick prioritizing.
    03-22-2012 02:50 PM in reply to: stevedb
    I've been watching this thread to see how far it gets off the orginal question. There is a thing called cycleing but if you think right-click is to much then so is that. Back when I had users that didn't like the osnap and using it I create a simple macro or lisp to set it as needed then reset it back after they finished drawing the line or what ever.
    Murph
    Supportting the troops daily.
    Please use plain text.
    Valued Contributor
    03-22-2012 02:54 PM in reply to: Murph
    ok Murph.
    since you said it.... lets have this cycling thing.
    At this point, I'm sufficiently intrigued, and ready for new stuff that I figure that knowing is better than just being told there's another toy, but you won't like it.
    So, please...
    go for it.
    TYIA.
    Distinguished Mentor
    thepworth
    03-22-2012 03:01 PM in reply to: Murph
    What! we never wander off topic.... oh, wait where was I...
    Say, if i mentally have to subtract out the highest & work my way down from the base 2 settings for osmode, think the software has to process the same way?  would be strange but...
    Also, I recall LDD days where the software was notorious for disabling Osnaps, but not renabling when the routine completed or if it crashed... If we have priority for inferring constraints, why not for osnaps????
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Murph
    03-22-2012 03:05 PM in reply to: stevedb
    stevedb wrote:
    ok Murph.
    So, please...
    go for it.
    TYIA.
    Press the TAB key when it asks for the point.
    http://autocad.autodesk.com/?nd=autocad_tips_tutorials_detail&adsk_tip_id=942
    Murph
    thepworth
    03-22-2012 03:07 PM in reply to: Murph
    Sweet!  learned something new!
    C3D 2011
    Murph
    03-22-2012 03:12 PM in reply to: thepworth
    And to think I didn't have to bill you for it.
    Maybe that's why I'm sitting here eating a frozn pizza for supper instead of a home cook meal.
    Murph
    Valued Contributor
    03-22-2012 03:59 PM in reply to: Murph
    Ok, I must be missing something.
    I click the tab button and it cycles back and forth from the distance to the angle.
    ok... I just did it again, this time overlying an endpoint, and I began to see where it appears to cycle through the active osnap elements. Is this what you're talking about?
    definitely-- you should be enjoying a homecooked meal. Eating frozen pizza will catch up to you in your 40's and 50's.
    thepworth
    03-22-2012 04:00 PM in reply to: stevedb
    I suppose you have dynamic input enabled - try turning it off from the buttons on the bottom of the screen
    C3D 2011
    thepworth
    03-22-2012 04:01 PM in reply to: Murph
    Here's the local brew to go with your pizza... :smileywink:
    C3D 2011
    Murph
    03-22-2012 04:07 PM in reply to: stevedb
    Yes, the osnap cycleing. Told ya you may not like it.
    I'm past those numbers already :smileyhappy:
    Murph
