• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    Accepted Solution
    osnap pick prioritizing.
    239 Views, 22 Replies
    03-16-2012 07:36 AM
    morning all.
    In selecting a point in a drawing to connect new poly lines to existing objects, is there a way to set the order to which osnap elements are used?
    I have perhaps 1/2 of the osnap element settings activated. End point, Mid point, Node, Intersection, etc......
    When I go to select, it's like everything EXCEPT End Point is recognizing. And while I can go to right click, and select end point, I am now wondering, if besides the rt click, there is a way to preset the priority, or order in which the osnap elements recognize the type.
    Without restting the settings each time.
    TGIF.
    I hope this is clear. If not, please let me know.
    TYIA.
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: osnap pick prioritizing.
    03-16-2012 08:39 AM in reply to: stevedb
    Never heard about the ability of sequencing the snap order..
    Why don't you simply switch off the Osnap feature (toggle F3) and choose what you desire with SHIFT-RIGHT on objects?
    Valued Contributor
    03-16-2012 08:44 AM in reply to: stevedb
    Good morning AV.
    I had done that in the past. It finally got on my nerves, so I stopped.
    Active Contributor
    03-20-2012 10:07 AM in reply to: stevedb
    Distinguished Mentor
    thepworth
    03-20-2012 03:13 PM in reply to: stevedb
    or you could try setting your F# keys as in the following thread:  http://www.cadtutor.net/forum/showthread.php?32028-Autosnap-priorities.  I don't know anyway to say 1) endpt 2) mid ..... x) nearest  would be a cool feature.  perhaps you should post to the AUGI wishlist - the top 10 frequently get addressed as "hot items" for the next release - if you're voted highest you might even get an AU pass...
    Personally I use shift-right click + the keyboard hotkey for the selection menu
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Valued Contributor
    03-22-2012 09:44 AM in reply to: thepworth
    Interesting.
    It appearsthere's a lot of irritation and discussion on this idea.
    I did not know about osmode before. I checked mine, and it's set to 2185, and there's nothing about 2185 in the list  on the docs page. I have however printed it out, and will keep it handy for now.
    Looking at the information I printed, I'm curious it this is like selecting color shading by rgb #'s.
    C....u...r....i....u....o.....s..... indeed.
    Thank you.
    thepworth
    03-22-2012 09:49 AM in reply to: stevedb
    I haven't tried select by RGB colors, but some of the new commands are 2010 - SelectSimilar (available from right click) and 2011 - AddSelected
    Note, only if you type in the command for "Selectsimilar" do you get a chance to use SEttings - which allows you to say similar based on color, layer, linetype, linetype scale, lineweight, plot style, object style, or name.  the "Color" setting does not drill down to RGB versus ACAD named/numbered & I haven't tried it with a "true color" shaded object.
    Doesn't do much for OS prioritizing, but it is something useful.
    C3D 2011
    Valued Contributor
    03-22-2012 10:00 AM in reply to: thepworth
    The selecting of rgb colors was in older AutoCAD versions that I'd used.
    I seldom used it, because I'm lousy with colors. I failed kindergarten because I liked 5 colors, and hated lines. :smileytongue:
    But, every so often I'll get in, tinker around, and find something I like.
    That said, My main goal was to get an undesired osnap object to be ignored, and having to right click, do the movement of the cursor seemed too tedious.
    However, as my f# keys are already programmed, I don't like the idea of programming them any more than the basics.
    I think at this point I'll need to play around with osmode and see what it does. What surprises me about it so far is that when I called it up, it asked for a new number, and not knowing what the choices were, I went looking on the docs page. After I'd found it, I notice it has a series of base 2 choices (0, 1, 2, 4, 8, 16, 32, etc.... to 8192, and 16383- which also is not base 2). As 2158 is not base two, I was surprised, and the rgb memories flooded through my mind.
    thepworth
    03-22-2012 10:04 AM in reply to: stevedb
    I think that the way it goes is that it takes the sum of the values for each option selected from
    0 NONe
    1 ENDpoint
    2 MIDpoint
    4 CENter
    8 NODe
    16 QUAdrant
    32 INTersection
    64 INSertion
    128 PERpendicular
    256 TANgent
    512 NEArest
    1024 QUIck
    2048 APParent Intersection
    4096 EXTension
    8192 PARallel
    So if you enable END (1) + MID (2) + Per (128) the OSMODE value would then be 131 - which is why you loose the base 2 form...
    C3D 2011
    Valued Contributor
    03-22-2012 11:19 AM in reply to: thepworth
    ok. I get it now..... doh!
    The Osmode number I got was 2185, not 2158.... I hate transposing numbers.
    So, my selection to get me there is
          1 end
          8 node
     128 perpendicular
    2048 apparent intersection.
    2185
    ta-da......
    so, if I go in, and set my osmode, by selecting my summed valued choices, that will keep me going.
    I see however I cannot do so while I am in an active line, or polyline action. Which takes me back to the right click, and select routine. Well, hey. I now know one more thing than I did two hours ago.
    thank you. Again.....
