• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Nievinski, Felipe
    no dialog boxes (and both cmddia and filedia = 1)
    905 Views, 2 Replies
    12-04-2001 04:01 AM
    Hi.
    Is there a known solution for the problem below?
    I'm experiencing the same.
    Thanks in avance.
    Felipe.
    George Anderson escreveu na notícia de
    mensagem <3B6720F6.2C64D69A@eweb.eugene.or.us>...
    > I sure hope someone can point me toward the variable I can not seem to
    > find.
    > No dialog boxes are being presented from picks on the Map toolbar.
    > Attach, Object Data, if I select it I get a command line response.
    > AutoCAD toolbar picks like hatch present a dialog box but nothing from
    > either Map toolbar.
    > I've double checked cmddia and filedia. Both are set to 1. Is there a
    > variable I'm missing that effect the Map commands specifically?
    > Please hurry, I want my dialogs back.
    > Thanks in advance,
    > George
    Please use plain text.
    *Nievinski, Felipe
    Re: no dialog boxes (and both cmddia and filedia = 1)
    12-04-2001 04:28 AM in reply to: *Nievinski, Felipe
    And expert (another system variable) = 0 ("all prompts are issued
    normally").
    I suspect it is some ACADMap's setting.
    Any hint?
    Felipe.
    Felipe Nievinski escreveu nas notícias de
    mensagem:918FC57D07C697EE509CA9C7EC38E4D4@in.WebX.maYIadrTaRb...
    > Hi.
    > Thanks in avance.
    > Felipe.
    > > find.
    > > either Map toolbar.
    > > Thanks in advance,
    > > George
    *Kumar, Ramana
    Re:
    12-04-2001 06:09 PM in reply to: *Nievinski, Felipe
    It looks like your Tools-->options->support paths are not properly set.
    Click on Tools-->Options-->File Tab
    Click on 'Support File serch path' tree node click on add and enter the
    full path where support directory is located from your map installation
    directory.
    For example on my system
    D:\Program Files\AdeskMap5\support
    D:\Program Files\AdeskMap5\fonts
    D:\Program Files\AdeskMap5\help
    Make sure you have above entries and close the Map and start the Map again.
    Hope this helps.
    Ramana
    "Felipe Nievinski" wrote in message
    news:ABF09BA4D263CCB5F0E3484BE6774035@in.WebX.maYIadrTaRb...
    > normally").
    > Any hint?
    > Felipe.
    > > Hi.
    > > Thanks in avance.
    > > Felipe.
    de
    > > > find.
    > > > either Map toolbar.
    a
    > > > Thanks in advance,
    > > > George
