• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    marking overlapping lines
    222 Views, 3 Replies
    07-31-2012 01:00 PM
    I need to find lines that overlap one another in a drawing and mark them, not delete them.  I am running AutpCAD Map 3D 2012.
    ~Sue
    Please use plain text.
    Product Support
    borycep
    Re: marking overlapping lines
    08-01-2012 02:31 PM in reply to: smvest
    Hi Sue,
    Thank you for posting to the Autodesk Discussion Groups.
    I would like to help you, but unfortunately, I do not understand your request.
    Can you please reply with a detailed problem description that includes a set of steps to reproduce? Screenshots might help too.
    Thanks!
    Phil
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
    Valued Mentor
    08-02-2012 02:38 AM in reply to: borycep
    your option if the lines are drawing objects
    cleanup tools - find duplicates
    if the line are on different layers .  qselect a layer to highlight the line on that layer
    shift select and delete one line copy and delete to see the line underneath, cntrl z to replace it.
    if the lines are FDO objects open the data table and select each line in the table
    post the types of line and details for a better answer
    dave
    *Expert Elite*
    antoniovinci
    08-02-2012 02:43 AM in reply to: borycep
    Dear Phil, there's nothing to understand: she simply wanna highlight the ovelapping lines, without deleting them.
    Here's my workaround, Sue:
    1. type in _MAPCLEAN
    2. set up like this
    3. in the next window, click on "retain.." and not on the default "modify.." like this
    4. after "Finish", you can isolate the layer SMVEST containing a copy of your overlaps
