• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    mapdist command
    152 Views, 2 Replies
    12-14-2012 05:24 AM
    When using the mapdist command the measurement is different from the actual line that I create. The map coordinates and the maptrack coordinates match. When I open a older drawing there is not an issue. Did I somehow change the origin of my template.
    Any suggestions thanks
    Here is sample from the command line
    Command: _mapdist
    Specify first point:
    Specify second point:
    Distance = 12.7513 (Foot)
    Azimuth = 38 degrees (forward), 218 degrees (reverse)
    Delta X = 15.0000, Delta Y = -0.0381
    Please use plain text.
    Product Support
    borycep
    Re: mapdist command
    12-18-2012 09:31 AM in reply to: dchristensen
    DIST calculates the distance between two points in space.
    MAPDIST calculates the distance as measured on the earth's surface.
    If no coordinate system is assigned to your drawing, DIST and MAPDIST will return the same values. If you assign a coordinate system based on a map projection for your DWG, then you will of course see a difference between the two measurements.
    Here is an example. I assigned HARN/WO.OR-S to my drawing, drew a polyline, and measured the distance of that line using DIST, and then MAPDIST. Here are my results:
    DIST
    Distance = 7.8132
    MAPDIST
    Distance = 7.7772
    I hope this makes sense :smileyvery-happy:
    Phil Borycens
    Support Specialist
    AEC Infrastructure
    Autodesk, Inc.
    Member
    Re: mapdist command
    01-15-2013 06:07 PM in reply to: borycep
    When drawing lines there is a difference between the line drawn and the mapdist measurement. Is there a way to draw the line so both distances are equal? David Christensen CAD/GIS Technician Marquette Board of Light and Power 2200 Wright St. Marquette, MI 49855 Office: (906) 228-0326 Cell: (906) 361-8237 Fax: (906) 228-0305
