• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    linking up a reciever to show position on an autocad drawing
    151 Views, 4 Replies
    05-04-2012 03:24 PM
    Hi guys,
    i have no idea where to put this so i hope someone can help.
    i wish to set up a mobile reciever device that can integrate with an autocad dwg drawing to show my physical location in the real world as a point on the drawing screen in real time.
    I guess you would say it would work exactly the same way a GPS map works however instead of using the GPS and street map i would be substituting in a construction site base station and autocad drawing.
    the point of reference would be located on a known point on the site (ie survey marker).
    any ideas?
    kind regards
    adam
    p.s the "Leica" system will not do the job for me. from my search so far it mainly works with elevations rather than lateral positioning in real time. i do not want to have to constantly move emitters and or receivers on the worksite in order to track my movements in real time and display them on the cad drawing i have in front of me!
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: linking up a reciever to show position on an autocad drawing
    05-05-2012 12:10 AM in reply to: adamjedgar
    I've never heard about a third-party extension to interface Autocad to a GPS.
    For free, here's a couple of workarounds:
    1] _MAPEXPORT your linework to shapefiles, then you load them in an opensource supporting realtime GPS (e.g. Mapwindow Gis)
    2] export somehow your drawing to .KML format, then you load it in Google Earth, which fully supports realtime GPS
    New Member
    05-05-2012 12:41 AM in reply to: antoniovinci
    i cant use gps its not accuracte enough. i need accuracy of not more than +/-20mm or less than 1 inch. thats why im thinking of an onsite emitter base station. it could use radio waves, laser or infra red in order to determine the receiver distance from the base station. the receiver position then needs to be displayed in autocad drawing file as a dot or crosshair or something like that.
    Distinguished Mentor
    thepworth
    05-07-2012 07:16 AM in reply to: adamjedgar
    I haven't seen real-time interfacing with AutoCAD, but you can work with a "Georeferenced DWF" and Design Review (free dwf viewer).  If it's not in the tutorials, look for "georeferenced dwf" as a skillbuilder.  DR can query a comm port for I/O from a receiver, so as long as your positioning can be pushed in the right format to a laptop it should work.
    Best of Luck & let us know if it works....
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Active Contributor
    05-12-2012 12:20 PM in reply to: adamjedgar
    It should be possible to develop some type of plug-in for this. What is the format of the data emitted by your device? The idea is to have an interpreterwithin the plug-in  that can generate (X,Y,Z) from the device data and diaplay positions in time intervals. Sounds doable.
    Gabriel
