• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    sergiu.sofronie
    level curves
    299 Views, 3 Replies
    10-01-2011 12:00 AM
    Hello ... I would like to know if I have a survey study (topographical study) of a terrain with lots of point in 3d coordinates, is there any way to generate the level curves automatically? Thanks
    Please use plain text.
    *Expert Elite*
    Betreff: level curves
    10-01-2011 12:51 AM in reply to: sergiu.sofronie
    what version of Map3D do you have?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Member
    sergiu.sofronie
    10-01-2011 01:30 AM in reply to: alfred.neswadba
    hello ... I have 2012 version x64.
    *Expert Elite*
    10-01-2011 02:48 AM in reply to: sergiu.sofronie
    besides that I don't think that points (without breaklines) are enough to create a surface ... you can:
    a) use command _MAPCREATESURFACE to create a DEM out of your points
    b) after creating the DEM Map3D displays it within the GIS-layer (in MAPWSPACE)
    c) right-click on the DEM-GIS-layer ==> and you get the option to create contour-lines
    One additional point to that: the precision is limited, I have not found a value to set the grid-size for converting the triangulation to the DEM.
    And the option would be to do that with Civil3D, I would prefere it, however I don't know if you have access to it.
    Good luck, - alfred -
    Alfred NESWADBA
