• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    *Leford
    import points file to map
    202 Views, 3 Replies
    11-12-2002 11:49 PM
    Is there an easy way to import a points file to Map.
    I have a text file containing Northerly, Easterly and elevation information
    and would like to import these points into Map 4. Additionally I would like
    to place point objects at each point.
    Thanks in advance for your help.
    Lee
    Please use plain text.
    *Medernach, Warren
    Re: import points file to map
    11-13-2002 04:00 AM in reply to: *Leford
    Hello Lee
    Check out Tony Ts site @ http://www.caddzone.com
    Check out his 'Free Stuff' section and there you will find a great lisp
    routine: ASCPOINT
    which allows the import of an ascii point file.
    Hope this helps
    Warren M
    IMAGINiT Technologies
    "Leford" wrote in message
    news:166D745F8D4AC2A008F0A28D3DF1D676@in.WebX.maYIadrTaRb...
    information
    like
    > Lee
    *M.
    11-14-2002 04:58 PM in reply to: *Leford
    Hi Leford,
    I could send you VBA macro to insert point, block or circle based on txt
    coordinat?
    Milos
    information
    like
    > Lee
    Re:
    11-20-2002 07:09 AM in reply to: *Leford
    Excellink works well for this as well.
    -Aaron-
