• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    Re: imageframe not working
    03-08-2012 07:57 AM in reply to: mazikhelela
    Thanks, that worked, I knew it had to be some variable that changed.
    Please use plain text.
    mazikhelela
    03-08-2012 01:26 PM in reply to: coswald
    maybe Autodesk should include documentation for the new variable
    Member
    01-08-2013 08:24 AM in reply to: coswald
    Thank you, you solved my problem! I am on Acad 2010 and could not get the Express Tools 'Tframes' command to work. Changing 'Frame' to 0 did the trick.I can now get on with my drawing!
    Valued Mentor
    01-09-2013 02:17 AM in reply to: coswald
    cursor over the image   does shift & left mouse click select the image?
    dave
