• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    GhyslainBaril2008
    Accepted Solution
    export object data to microsoft excel
    1196 Views, 7 Replies
    02-28-2012 01:03 PM
    I have a object data table attached to many polygon.  In this table i have 2 line of data.  I want to export in a tabloid like microsoft excel.  I know autocad have a command to do this...
    Thanks a lot for your help
    Please use plain text.
    *Expert Elite*
    Re: export object data to microsoft excel
    02-28-2012 01:20 PM in reply to: GhyslainBaril2008
    the way I know is:
    • save your drawing and close it
    • create a new drawing
    • attach the previous drawing with command _ADEDRAWINGS
    • query the objects from the attached drawing (command _ADEQUERY) and create a list as a result (instead of querying the objects into the active/new drawing).
    Good luck, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Valued Contributor
    ro_fr
    02-28-2012 11:15 PM in reply to: GhyslainBaril2008
    another way is to export your objects to ESRI SHP including the object data (command: _mapexport). It creates a DBase file (*.dbf) for the attribute data. The file can be opened in EXCEL.
    Rob
    *Expert Elite*
    antoniovinci
    02-29-2012 12:31 AM in reply to: GhyslainBaril2008
    Well, the quickest way to get your goal is probably this:
    1] issue the _MAPVIEWTBL command
    2] OK
    3] select all the rows, and then CTRL-C
    4] in Excel, paste them
    Member
    04-11-2012 02:49 PM in reply to: antoniovinci
    i have a problem like this issue...
    i have more features with some data properties in their schema
    like this
    feature1  geometry, prop1 (string), prop2(string)    etc.... etc...
    feature2  geometry, prop2 (string), prop3(string), prop4(string)    etc.... etc...
    feature3 ......
    so i like to have a table in wich i can view a complete report of all features whit their properties
    a manual way to do this il opening all data  tables, selecting coping and pasting in excel... but i'd like to find a command or macro way to do this automatically
    is there a way to do this by a query ? or better whit a spatial query ?
    thanks to all !
    *Expert Elite*
    04-11-2012 10:20 PM in reply to: harryplotter
    you can try to use _MAPEXPORT to create a SHP-file, select your objectdata tables to be included in export.
    After that is done you have 3 files created, a SHP, a SHX and a DBF ==> open the DBF in e.g. Excel.
    Is that what you were looking for?
    - alfred -
    Alfred NESWADBA
    Member
    04-12-2012 12:30 AM in reply to: alfred.neswadba
    hi alfred
    thank you very much for your answer
    yes it could be a very good solution
    but it does not work if i have only sdf geographical entityes in each feature. I've not defined any object classes, but only a schema and drawed geographical entities.
    I'm an expert user in Autocad but i'm newbee in map, so i don't know if my metod is very good....
    1) i've got cad drawings whit polilines and polygons,
    2) i've created a query after having associated them,
    3) i've exorted the queried entities to a sdf file,
    4) i've modified the schema, adding some property data,
    5) i've modified or added the geographical entities on each feature in the schema....
    now i have to make a report of all the entityes in excel....
    your method could be very good for me but it seems does not work whit sdf features....
    -marco-
    *Expert Elite*
    04-12-2012 12:50 AM in reply to: harryplotter
    Create a new drawing, us _MAPIMPORT to import your SDF and don't forget to create ODTables from the attribtive data in the SDF, then you can export as described.
    And if you alread have SDF, you can open the datagrid for each sdf and use copy&paste or export (under options, button on bottom of grid-view).
    Alfred NESWADBA
