• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    dxf missing header
    124 Views, 1 Replies
    02-14-2013 09:28 AM
    All,
        I have attached a dxf I recieved from another source that we want to convert to a dwg.  I have tried to open the file directly into autocad map3d 2013 but get an error:
    Error in drawing header on line 41663.
    C:\Users\JakeS\Documents\export.dxf is not valid DXF file
    Invalid or incomplete DXF input -- drawing discarded.
       I have researched a little on this and found that there appears to be a header that is missing.  My problem now is what do I add as a header to get past this error?
       Can I copy the contents of this using notepad and paste them into a blank drawing saved as a dxf?  If so, where can I paste these sections in at?  I have tried to paste them in before and after the EOF tag in a test dxf, and that prevents the error when opening, but it doesn't bring in any of the shapes.
    Thanks for any help you can provide.
    Please use plain text.
    *Expert Elite*
    Re: dxf missing header
    02-14-2013 01:31 PM in reply to: JakeSwanstrom
    you are right, more than the header is missing, also the 0...SECTION and 0...ENDSEC lines.
    I have imported that and saved it, but be careful especially about the UNITS (I did it in metric/meter), so maybe you have to scale it.
    HTH, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
