• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    drainage divide
    276 Views, 5 Replies
    09-24-2009 03:17 AM
    Does anyone know how to get the drainage divide lines from a layer with contour lines?
    Should I use Autodesk Civil 3D instead? How can I do it?
    Thank you
    Please use plain text.
    Active Contributor
    Re: drainage divide
    09-24-2009 09:40 PM in reply to: eduardocmoreira
    Civil 3D with Watersheds. I think it can be done in Map but will take more prep of the data.
    Kevin Clark P.E.
    www.inmotioncon.com
    *Joe Bouza
    Re: drainage divide
    09-30-2009 08:56 AM in reply to: eduardocmoreira
    Not to be snarky, but I have found it waaaay faster and straight forward to
    simple "Read" the contours and place a pline by hand. By the time you finish
    muckin' round with Watershed settings et al you would probably have it drawn
    in
    *Kevin Clark P.E.
    Re: drainage divide
    10-01-2009 08:12 PM in reply to: eduardocmoreira
    Civil3D watersheds
    wrote in message
    news:6260075@discussion.autodesk.com...
    contour lines?
    Thank you
    *Joe Bouza
    Re: drainage divide
    10-02-2009 05:38 AM in reply to: eduardocmoreira
    Hi Kevin, How do you deal with the "drainage notch" and "Flat area"
    boundaries created with that? Out Tributary area maps do not typically
    included those; (we have a mad scientist that decides where the water wants
    to go, for us )
    Joe
    *David Parker
    Re: drainage divide
    10-02-2009 03:27 PM in reply to: eduardocmoreira
    Check your shp file resources from states, counties, towns, etc. many have
    watershed files available.
    dave
    "Joe Bouza" wrote in message
    news:6264823@discussion.autodesk.com...
    to go, for us )
    Joe
