• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    convert .shp files to acad point blocks
    737 Views, 4 Replies
    07-20-2005 11:18 AM
    how to convert .shp files , that import as point objects, into acad point blocks with x,y,z values and attributes intact?
    Please use plain text.
    *Murph
    Re: convert .shp files to acad point blocks
    07-20-2005 11:23 AM in reply to: sbsmith
    With Map 3D you can grab the dbf file and use that to create/import points
    with the Civil tools. That will give you the Civil Object Point(s). If you
    want them as non-civil points, you can create a block with attributes and
    import the shp file using blocks and attributes option. May sure the
    attribute tags are the same as the field name of the shp file.
    Murph
    wrote in message news:4906653@discussion.autodesk.com...
    *Tripp Corbin
    07-20-2005 11:52 AM in reply to: sbsmith
    Dang you beat me to it Murph.
    Tripp Corbin, GISP, MCP
    Associate Vice President, GIS/Mapping
    ESRI Authorized Instructor
    Keck & Wood, Inc.
    www.keckwood.com
    (678) 417-4000
    (678) 417-8785 Fax
    Keck & Wood now offers Introduction to ArcGIS training classes. Contact me
    for more information.
    "Murph" wrote in message
    news:4906656@discussion.autodesk.com...
    Murph
    07-25-2005 01:31 PM in reply to: sbsmith
    NICE TRY , GUYS
    I GET "Unrecognized database format" for my .dbf file
    i tried different import formats but nothing worked
    anymore ideas?
    *Murph
    07-25-2005 02:06 PM in reply to: sbsmith
    Did you try the map import command, not the civil import points? Create a
    block from a acadpoint with the attributtes tags the same as the shp field
    names. Import the shp file with the block option.
    BTW "Unrecognized database format" is pretty command using anything other
    than a MS Office data file.
    Murph
    wrote in message news:4910506@discussion.autodesk.com...
    NICE TRY , GUYS
    anymore ideas?
