AutoCAD Map 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
convert shape file feature id to autocad text
- Highlight
- Email to a Friend
- Report Inappropriate Content
I am working with a country grid shape file that has 2994 grid numbers. I am trying to convert the shape file to an autocad image. However, about one-third of the feature ID's do not save into the new autocad drawing. Is there a way to just select a portion of the shape file to convert into a drawing? Or just convert all the feature id's and not the grid shapes?
Re: convert shape file feature id to autocad text
- Highlight
- Email to a Friend
I would (one of many possible ways):
- use command _MAPCONNECT to connect to the shape.
- then modify the stylization so the text with the id's show up
- and last but not least save the map as DWG
So what way have you tried?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
- Highlight
- Email to a Friend
You could bring in just the numbers as text: http://screencast.com/t/R425WIxOv1
Otherwise, could you give more details on the process that you are currently using to make an "autocad image"?
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
- Highlight
- Email to a Friend
Along with Nates's answer you can do a spatial filter when you import and import just the area you need instead of the whole area of the shp file.
Supportting the troops daily.
- Highlight
- Email to a Friend
You could simply install the virtual printer "TIFF uncompressed", then plot to the file by window.
