• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Contributor
    Accepted Solution
    color saturation
    230 Views, 4 Replies
    09-20-2012 12:08 PM
    Is there a way to find the RGB color saturation for attached FDO objects when they are themed. I have looked under properties but there does not seem to be a way to find it. I would like to use the same color saturation for text in the drawing that has the attached shp files. Autocad map 2013.
    John
    Please use plain text.
    *Expert Elite*
    Murph
    Re: color saturation
    09-20-2012 03:18 PM in reply to: JohnPM
    If you save the themed layers to a .layer file you can open the .layer file with an xml reader or notepad and get the colors in hexadecimal notation which you then can find the RBG. http://www.w3schools.com/html/html_colors.asp
    Murph
    Supportting the troops daily.
    09-20-2012 03:41 PM in reply to: Murph
    I will give that a try. thanks John
    *Expert Elite*
    antoniovinci
    09-22-2012 06:04 AM in reply to: JohnPM
    The quickest way to achieve that goal, in my opinion, is:
    1] in Autocad view, click Print Screen
    2] in the free Irfanview, press CTRL-V
    3] now SHIFT-LEFT MOUSE to copy the hex RGB value to the clipboard (e.g. black = 000000, white FFFFFF, yellow FFFF00, and so on)
    09-23-2012 02:42 PM in reply to: antoniovinci
    I found the solution by selecting the fill color in the style editor and going to more colors. The RGB saturation is already selected for the feature as the default. I did not see this earlier. It would be helpful to have this available in the properties of a checked out feature. Thanks John
