• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    avoc42
    bringing in xyz points
    191 Views, 5 Replies
    06-18-2012 11:35 AM
    Hi There,
    I'm using mapimport to bring in xyz points and they have come in ok, except that they are flipped horizontally.
    (they come in as a block)
    Any ideas on how to flip them back?
    Perhaps there is a command that rotates objects all at one time *not* based on one central point..
    Any help would be greatly appreciated.
    Thanks!
    Please use plain text.
    Valued Mentor
    Re: bringing in xyz points
    06-18-2012 12:12 PM in reply to: avoc42
    does flipped mean 180 degrees on y axis? as in your x values are negative instead of positive or vice versa?
    Member
    avoc42
    06-18-2012 06:20 PM in reply to: avoc42
    They do appear to be simply flipped 180 deg. The points come directly from the gps unit, so perhaps the data needs to be changed in some way before importing....
    I have not yet tried inserting a negative sign in the CSV file. I'll try it in the morning.
    06-21-2012 02:35 PM in reply to: avoc42
    then I guess that your columns for X and Y have to be changed.
    - alfred -
    Alfred NESWADBA
    Product Support
    06-22-2012 06:23 AM in reply to: avoc42
    You might just need to change the sign on the X values.  If you are in the western hemisphere, sometimes a GPS will record the X value as positve, and indicate otherwise that is it W, but a LL or similar CS in Map will expect -42 for example, not 42 and a W in a separate column.
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
    Member
    avoc42
    06-22-2012 08:45 AM in reply to: avoc42
    Thanks! I tried a bunch of different variations on putting a negative sign in front of the x and the y... I'm working in UTM83 zone 12.
    I did get it working ok, now just need to figure out why only portions of the data are completely off. That's a question for a different forum though.
