• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Member
    Z coordinates
    169 Views, 9 Replies
    03-13-2012 02:16 AM
    Is there any way to multiply the value of Z coordinate for many points selected, in the same time? For example, I selected many points, and need to double their Z value, but on an easier way, not one by one? Thanks
    Please use plain text.
    antoniovinci
    Re: Z coordinates
    03-13-2012 03:18 AM in reply to: Goxy
    One way is to export those points to a shapefile, then perform the calculation in the .DBF (in Excel or similar), and _MAPIMPORT the edited shapefile back to Autocad.
    Member
    Re: Z coordinates
    03-13-2012 03:25 AM in reply to: Goxy
    Thanks a lot. I'll try, and hope it will work, cause I'm beginner in Map 3D. Thanks again.
    antoniovinci
    Re: Z coordinates
    03-13-2012 03:45 AM in reply to: Goxy
    Please pay attention to this point: if you manually edit a .DBF file belonging to a shape-set, you can add or erase columns in the spreadsheet, but it's NOT allowed to add or erase rows.
    Valued Mentor
    Re: Z coordinates
    03-13-2012 05:31 AM in reply to: antoniovinci
    If you only need the calculation, export the pint with the z value as a property, put  the sdf into a map and open the data table, calculate z*2.
    Do you need to move the points or create a new set of points at the new z value?
    Member
    Re: Z coordinates
    03-13-2012 07:01 AM in reply to: antoniovinci
    Thank you
    Member
    Re: Z coordinates
    03-13-2012 07:17 AM in reply to: parkr4st
    Actually, I attended to move plenty of points along the Z axe. To duplicate Z value for all the points in the same time, but as I'm a beginner, didn't know how. I tought, it must be that it is easy. Maybe it actually is, but when you are not familiar with Map 3D, it seems dificult. Now I have some inputs and ideas, so I'll try. Of course, it needs much more time for me. Thanks a lot
    Distinguished Mentor
    thepworth
    Re: Z coordinates
    03-13-2012 07:23 AM in reply to: antoniovinci
    I believe that a recent problem with the suggestion of editing a .dbf is that MS Excel 2010 no longer allows you to save back in the DBase IV format.  However, a work-around I found was a gentleman in Australia selling a "add-on" re-enabling this feature for $30 US.
    Just want folks to be aware before investing too much labor. :smileyhappy:
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Product Support
    Re: Z coordinates
    03-13-2012 01:45 PM in reply to: thepworth
    OpenOffice will allow a save back to .dbf also.(and it's free and will handle the native .xls files as well)
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
    thepworth
    Re: Z coordinates
    03-13-2012 01:47 PM in reply to: NateMoore
    True, thanks for bringing it up - I use it on my personal machine & forgot to mention.... :smileyhappy:
    C3D 2011
