AutoCAD Map 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Xref Disappears on Zoom In (Map 3D 2011)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a georeferenced drawing with aerial photos and linework that I have Xref'd in a recent survey drawing. I checked that the coordinate systems match and the xref shows that it is loaded and the layers are listed as on and thawed.
However, the xref is not visible.
I tried a new blank drawing using the Map 3D template, same coordinate system. Same thing happens. However, this time, I noticed that the xref is visible when zoomed out. When I zoom in, it disappears. Screen shot attached.
Re: Xref Disappears on Zoom In (Map 3D 2011)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
looks like your Autocad view setup is for a 3D orientation instead of 2D top down, but the view cube doesn't show in the screenshot. My "guess" is based on seeing a section of the Z axis in your crosshairs.
Unless you go to 3D viewing from the Map Status bar at the bottom of the screen, sometimes using the "vanilla" autocad 3D view settings can cause issues.
Just a guess, but let's see if anyone has $.02....
TdH
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've attached an updated screenshot showing the view cube.
To me, it seems like AutoCAD is hiding the xref at a particular zoom level. If I use my mouse wheel to zoom in and out, the xref appears and disappears.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
humor me with this one - in the lower right of the viewcube is a dropdown arrow. expand the flyout and see if it's set to perspective or parallel. should be parallel.
beyond this, unless someone set a zoom scale on it (very unlikely), i'm not sure what else to try ![]()
C3D 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It is set to parallel. But, you gave me another idea!
If I switch to 2D view rather than 3D, the problem seems to go away. Now, I need to check my original drawing.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What happens if you copy&paste it (complete modelspace content) into a new drawing and run then ZOOM?
Question 2: have you set some scale-handling in the MAPWSPACE-dialog?
- alfred -
Alfred NESWADBA
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, setting the drawing to 2D view solved the problem. I didn't try anything else due to time constraints.
