• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Contributor
    World Files Not Recognised
    377 Views, 6 Replies
    06-18-2012 03:21 AM
    I am trying to insert Geo-referenced TIF files into Map 2013 but the associated World files are not being found/recognised even though they are in the same directory as the image. I have tried both TAB and TFW using MAPIINSERTand Data Connect.
    Going back to Map 2012, which we still have in the office, the World files are found and correlated correctly with both of the above World file types and Map commands.
    I can do what I need to do in 2012 for the moment but has anyone else had this problem?
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: World Files Not Recognised
    06-18-2012 04:05 AM in reply to: Neil47
    Try to embed the .TFW file in the header of your .TIF, by means of the free GeoTiffExaminer tool, sir.
    Valued Contributor
    06-19-2012 03:29 AM in reply to: antoniovinci
    Thanks for the tip, it's a nice tool and has provided a work round for the problem I'm having although I'd still like to know why Map was not finding the world files.
    *Expert Elite*
    antoniovinci
    06-19-2012 05:30 AM in reply to: Neil47
    Feel free to paste here the content of that Worldfile, thanx.
    Valued Contributor
    06-20-2012 12:21 AM in reply to: antoniovinci
    As noted in my first post these are both found and used by Map 2012 to locate the raster file correctly but not by Map 2013 - hopefully thwe layout of the contents isn't lost in the formatting of the post
    Contents of TFW file are
    1.000000000000000
    0.000000000000000
    0.000000000000000
    -1.000000000000000
    335000.500000000000000
    134999.500000000000000
    And contents of TAB file are
    !table
    !version 300
    !charset WindowsLatin1
    Definition Table
      File "ST33SE.TIF"
      Type "RASTER"
      (335000,130000) (0,5000) Label "Pt 1",
      (340000,130000) (5000,5000) Label "Pt 2",
      (340000,135000) (5000,0) Label "Pt 3",
      (335000,135000) (0,0) Label "Pt 4"
      CoordSys Earth Projection 8, 79, "m", -2, 49, 0.9996012717, 400000, -100000
      Units "m"
    *Expert Elite*
    antoniovinci
    06-20-2012 02:18 AM in reply to: Neil47
    Are you REALLY sure that .TFW file name is ST33SE like its own TIFF ?
    If so, erase or move the original .TFW anywhere, then with GeoTiffExaminer recreate it from the Geotiff already existing, and try again in Map2013.
    New Member
    08-23-2012 04:42 AM in reply to: Neil47
    The same thing happened to mee too...
    Georeferended .tif image in the right position with civil 3d 2012. .tfw file not recognized in civil 3d 2013....
