• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    Workspace in Map 3D 2013
    508 Views, 7 Replies
    10-08-2012 11:53 PM
    I have set up my workspace as i like it, & saved it as 2013, then ticked it as current.
    When i close then open Map 3D 2013, the workspace has switched to planning & analysis
    workspace, which has mysteriously become ticked.
    Can anyone help please, thanks in advance
    Please use plain text.
    Distinguished Contributor
    bingeomatics
    Re: Workspace in Map 3D 2013
    10-09-2012 02:15 AM in reply to: Ronaldo54
    You must change in "Workspace settings" Switching parameter to "Automatically save workspace changes"
    Binnat Khalilov
    Active Contributor
    10-09-2012 03:45 PM in reply to: bingeomatics
    Yeah, I've done all that, still does not save when I close then reopen ACAD!!!!
    bingeomatics
    10-09-2012 11:58 PM in reply to: Ronaldo54
    Then attempt to open "Customize User Inteface" window and there on the workspace style which you want right click and set "Set current".
    Binnat Khalilov
    Active Contributor
    10-15-2012 05:32 PM in reply to: bingeomatics
    Hasn't worked either, but thanks anyway. Don't know why they make things so difficult!!!!
    Product Support
    10-16-2012 06:41 AM in reply to: Ronaldo54
    In 2012 this was quite common.  If you still can't get it to stay as set, the startup switch options here might help: http://gisexchange.typepad.com/blog/2011/05/map-2012-default-workspaces.html (also be sure that you have all the updates applied).
    Nate Moore, GISP
    Geospatial Premium Support Specialist
    Global Services
    Autodesk, Sarl
    Active Contributor
    10-16-2012 03:53 PM in reply to: NateMoore
    thanks nate,
    i have tried everything and still no good.
    i will have to put up with it i think!!!!!
    *Expert Elite*
    10-17-2012 01:44 AM in reply to: Ronaldo54
    Also the answer(s) in >>>the other thread<<< you started ....?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
