• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    neilyj
    Where's transparency selection?
    286 Views, 20 Replies
    06-10-2011 01:34 PM
    Working through the 2010 tutorials (using 2012) and can't find how to change the transparency for the style. The tutorial screenshot show a big foreground trasnparency box but can't see it in 2012.
    It seems to be ok in 2011 so how do I do this in 2012
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Please use plain text.
    Murph
    Re: Where's transparency selection?
    06-10-2011 01:49 PM in reply to: neilyj
    Looks like it is suppose to be on the Ribbon Style tab but got misplaced along the line.
    Murph
    Supportting the troops daily.
    Valued Mentor
    06-10-2011 03:36 PM in reply to: Murph
    Style tab, style section, click the small arrow pointing to south east to right of "Style" in bottom bar.  Opens style polygon window. you can set transparency there and advanced sets origin control.  The same arow to the right of "Label" opens the style lable wiindow.
    Dave
    neilyj
    06-12-2011 01:26 PM in reply to: parkr4st
    Thanks for this - i had found that one - but my point was that you only seem to be able to alter each polygon individually rather than via a global transparency value as in 2011. If you have a lot of colours to change it becomes very tedious.....another one to raise with Autodesk Support, may as well get my subscription money's worth.......
    neilyj
    Valued Mentor
    06-13-2011 02:13 PM in reply to: neilyj
    i made it to a contact @ AD  MMorales@Microdesk.com  I tried to explain the problem and was sent the single transparency setting routine as an answer. I have returned a reply trying to explain the slider in 2011 New Theme dialogue.  Missed the point.  Perhaps you could alos ship a message explaining you too are not impressed.
    Dave
    neilyj
    06-14-2011 06:20 AM in reply to: neilyj
    Have raised a support request for this and a few other anomalies I've recently found in Map
    neilyj
    06-16-2011 01:28 PM in reply to: neilyj
    Right click the layer choose style,  under the Symbol and style function you will see the border color, and the fill color.  Clock on the fill, you will see a transparency bar show up below 0-255
    neilyj
    06-17-2011 12:08 AM in reply to: neilyj
    Thanks for this - that does each colour individually but how do you adjust the whole theme (as you could in 2011) - it not really feasible to do each individual colour band if you have a lot of colours.....
    neilyj
    06-17-2011 05:14 AM in reply to: neilyj
    ahh, I know see your issue.
    neilyj
    06-17-2011 05:30 AM in reply to: neilyj
    A definite backward step - perhaps because it's only "Map 3D Lite" that is included with Civil 3D..........
    neilyj
