• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Contributor
    WORLD UCS ROTATED
    528 Views, 7 Replies
    08-31-2012 08:36 AM
    The World UCS seems to be rotated for some unknown reason.
    If I change it to Plan view everything seems fine but it still bothers me.
    I have not used dview twist; it is set to 0.
    This seems to be an issue since I updated to Map3D 2013 64bit.
    Is anyone else having this problem?
    Thanks!
    Alicia
    Please use plain text.
    Re: WORLD UCS ROTATED
    08-31-2012 09:00 AM in reply to: amm30165
    The WORLD coordinate-system within a drawing can't be rotated or modified in any way. Why do you think that it is rotated?
    If you open a drawing in 2013 what is different to the previous AutoCAD Map3D you had?
    - alfred -
    Alfred NESWADBA
    Active Contributor
    08-31-2012 09:06 AM in reply to: alfred.neswadba
    The view cube in the upper right hand corner (with North, South, East and West) is not straight.; looks rotated about 10 degrees to the NE.
    Alicia
    08-31-2012 09:19 AM in reply to: amm30165
    if UCS is really set to WORLD, then your view is twisted, not the world-coord is rotated. It's just like you rotate your head, that does not rotate the world :smileywink: :smileywink:
    Well, you said it, command _PLAN and option _WORLD and you look parallel to world ucs (north is up).
    - alfred -
    Alfred NESWADBA
    antoniovinci
    08-31-2012 10:02 AM in reply to: alfred.neswadba
    Yep, or more simply: type in _UCS and double enter...
    Active Contributor
    08-31-2012 10:30 AM in reply to: antoniovinci
    I appreciate all of the replies.
    I have been working with AutoCAD for 20+ years and have not experienced this before.
    Maybe the attached png will help to explain my problem....
    Why does the view cube look exactly the same in every drawing I open?
    The ucs icon is squared up and not a named or object aligned ucs; the view has not been twisted.
    My drawings did not look like this when they were saved to a version provious to 2013.
    Did I unknowingly change a setting to something?
    thanks,
    Alicia
    08-31-2012 10:40 AM in reply to: amm30165
    can you verify the sysvars
    UCSFOLLOW (should be tried with 0)
    if you start _GEOGRAPHICLOCATION ... are you asked for removing a geogr.position? If so answer with "remove" and look again to your drawing with _PLAN _WORLD or press onto "TOP" on your viewcube.
    If none of these options work, please click on "TOP" and let us see the screenshot then.
    - alfred -
    Alfred NESWADBA
    Active Contributor
    08-31-2012 10:52 AM in reply to: alfred.neswadba
    Removing the current geographioclocation fixed the world UCS.  Everything is squared up again.
    Thanks so much!!!
    I appreciate your patience.
    Alicia
