• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    rl88
    WMS Connection in Map 3D 2012
    309 Views, 2 Replies
    06-25-2012 11:56 AM
    I'm trying something I believe to be fairly basic:  I'm trying to get some basemapping into my Map 3D drawing.
    In particular, I need to get the World Street Map found here:  http://www.arcgis.com/home/item.html?id=3b93337983e9436f8db950e38a8629af
    In Map, under Data Connections, I'm using "Add WMS Connection"
    I give the connection a name, enter the Server name, and leave Version on "Default version"
    I leave username and password blank.
    But I always get the error message:  "Failed to connect."
    Any ideas?  Do ESRI and AutoCAD just not play well together?
    Please use plain text.
    jens.kuegl
    Re: WMS Connection in Map 3D 2012
    06-26-2012 08:17 AM in reply to: rl88
    This basemap is not a "WMS service". So you can not add it with an FDO WMS conection.
    This basemap is an "ArcGIS image service".
    Jens
    Active Member
    rl88
    06-29-2012 05:53 PM in reply to: rl88
    I don't understand all that FDO connection stuff.  A smart guy at CADSoft pointed me to Basejump, which is awesome, just what I needed.
