• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Active Member
    Viewshed/Line of Sight Possible??
    371 Views, 6 Replies
    10-05-2005 02:58 AM
    Hi All,
    I am normally a user of ESRI ArcGIS where you can run Viewshed analysis, to analyse what can eb seen froma particular place.
    I am hoping that this is possible in Map3D - and that the line of sight or viewshed can be done in 3D.
    To give an example -
    On a hill what can be seen from a specific location - and have structures that restrict this.
    if this possible - thanks in advance
    Please use plain text.
    *Natan Elsberg
    Re: Viewshed/Line of Sight Possible??
    10-05-2005 09:23 AM in reply to: TJMartin
    Hi there,
    Check out RDV - Rapid Design Visualization.
    It has a whole bunch of tools to give you the same type of GIS visual
    analysis that you can get from the ESRI products.
    We have dedicated versions for Civil 3D, Map 3D, and Land Desktop which
    support the functionality you are looking for.
    You can download a fully functional, time-unlimited non-commercial
    evaluation version free from the website:
    www.rdvsystems.com
    Good Luck,
    Natan
    natan@rdvsystems.com
    www.rdvsystems.com
    Rapid Design Visualization - Visualization Made Simple
    wrote in message news:4975738@discussion.autodesk.com...
    Hi All,
    that restrict this.
    Distinguished Contributor
    10-05-2005 10:40 PM in reply to: TJMartin
    Natan,
    Can you give examples (I don't see any on your website) of the viewshed analysis abilities of RDV? In particular, how does it handle multi-point viewshed analysis? Can it output viewshed polygons (and in the event of multi-point visibility, viewshed polygons specifying the number of points that the polygon is visible from?)?
    Andrew Schroeder
    Active Member
    10-06-2005 01:01 AM in reply to: TJMartin
    I also downloaded the RDV System for my Map 3D and all though i like the extras for the visualisation cannot find the analysis section?
    Does it exist?
    Or do you have to buy the full version?
    Anyone else know how the Line of Sight or Viewshed can be done within Map3D???
    *Natan Elsberg
    10-06-2005 02:16 AM in reply to: TJMartin
    Hi Group,
    Sorry for the misunderstanding. We will have some viewshed analysis
    functionality posted in the near future. We have it already finished
    in-house and an older shipping version for Land Desktop is available. The
    Map3D version will be available in second half of Ocotober, but we will work
    right now to try and post some examples of the output already in the next
    few days on our site.
    Yours,
    Natan
    www.rdvsystems.com
    wrote in message news:4977094@discussion.autodesk.com...
    Does it exist?
    Map3D???
    *Natan Elsberg
    10-06-2005 07:52 AM in reply to: TJMartin
    http://www.rdvsystems.com/site_new/samples/gis/mpv/index.html
    The above is a link to an example we just put on our site which should give
    you a good idea of how our solution works.
    It shows a multipoint viewshed analysis for 3 buildings built into the
    terrain. There are separate layers which can be turned on and off showing
    the results for visibility analyses from all 3 points or combinations of the
    3.
    As posted in another message on this thread, the functionality for creation
    of this type of example will be available shortly.
    Anyone who would like more information at the moment is invited to contact
    me directly on the matter.
    Good Luck,
    Natan
    www.rdvsystems.com
    Hi All,
    that restrict this.
    11-21-2012 07:31 PM in reply to: *Natan Elsberg
    Hi All,
    I found this thread have been posted for over 7 years. Is there a feature can cater the viewshed/ line of sight application? :smileyhappy:
    Eric
