• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Neilw
    Use table object to display linked table
    111 Views, 1 Replies
    11-20-2012 08:24 AM
    I am wanting to use an Autocad table object to display fields from an Access database table that is linked to symbols in my drawing.
    My objective is create a database table that has detailed notes for call outs in my drawings and then link my call out blocks to the database table and display the blocks and linked descriptions in an Autocad table. If the notes in the database table are edited the Autocad table updates with the new the description from the database.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    Please use plain text.
    Valued Contributor
    Re: Use table object to display linked table
    11-20-2012 02:29 PM in reply to: Neilw
    Hi Neil,
    I have not yet come across a way to do this with access, but if you use the "table" command, you have the option to use a link to an external Excel table.  I can't test this, unfortunately, because I don't have Excel loaded locally, and it won;t let you do anything without that.
    As a work around, I believe that you can export an Access Table to an Excel format, and then use the excel table as a data link and make an AutoCAD table based on that link.
    Hope that helps.
    Norm
