• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Valued Mentor
    Unhandled Exception in CUI
    276 Views, 5 Replies
    07-06-2011 02:43 PM
    If you key in CUI, and change the "Command List" to "All Commands and Controls",  an Unhandled Exception is generated.
    See attached.
    Please use plain text.
    Product Support
    Re: Unhandled Exception in CUI
    07-08-2011 04:04 AM in reply to: fieldguy
    I cannot reproduce this in AutoCAD 2012. Also you screenshot seems to be not from pure AutoCAD.
    What product exactly is it that you are running?
    Best regards,
    Silvia
    Silvia Menon
    Support Specialist
    Product Support
    http://www.autodesk.com/autocad-support
    Valued Mentor
    07-08-2011 01:50 PM in reply to: Simenon
    Hello and thanks for the reply.  I am using Autocad Map 3D 2012 64 in Win 7 Pro.  My mistake - I considered this an issue in core Autocad.  About reports this as Product Version: F.51.0.0.
    Can you move the post to Map 3D for me please?
    Product Support
    07-11-2011 12:49 AM in reply to: fieldguy
    no problem, I have now moved the thread from the AutoCAD forum to the AutoCAD Map 3D Forum.
    Best regards,
    Silvia
    Silvia Menon
    Support Specialist
    Product Support
    Product Support
    Brigitte.Koesterke
    07-11-2011 02:19 AM in reply to: Simenon
    the behavior you described with the CUI showing up the message with choosing “All Commands and Controls” is due to a known issue that is currently under investigation by our development team.
    Unfortunately there is no possible workaround to avoid this message. However, in general the error message doesn’t affect product functionality, and it is possible to click “Continue” for working without any other message and having the full functionality of the CUI.
    Kind regards
    Brigitte
    Brigitte Kösterke
    Support Specialist
    Product Support
    Valued Mentor
    07-11-2011 08:01 AM in reply to: Brigitte.Koesterke
    Thank you both!
