• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    New Member
    Unhandled Exception errors ?
    111 Views, 1 Replies
    02-06-2013 01:23 PM
    I have a user running into these errors when saving documents can you please take a look and suggst a solution please.  Below is the process he does upon the first error.  After the final error the program saves the document and returns to normal function.  As well this error does ot happen all of the time.
    1 - Automatic
    2 – After ‘Ok’
    3 – After ‘Ok’
    4 – After ‘Ok’
    That’s all
    Please use plain text.
    Product Support
    borycep
    Re: Unhandled Exception errors ?
    02-07-2013 03:26 PM in reply to: licensing
    That's all? :smileywink:
    Wow!
    Could this be an issue with the user's Support File Search Path (AutoCAD OPTIONS > Files tab)? I'm attaching a copy of mine for you to use as a comparison.
    Remember that any custom paths need to be added BELOW the built-in Autodesk paths. Order matters in the Support File Search Path.
    Phil Borycens
    Support Specialist
    AEC Infrastructure
