• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Map 3D
    Distinguished Mentor
    thepworth
    Re: Unable to conect to excel file using ODBC FDO provider
    05-03-2012 01:03 PM in reply to: chierchio
    in this case, the data is extended attributes (water quality sampling for MCL's) against existing wells.  Since the I'm attaching to a .SHP from the state well data set, I'm intending to perform a join to stylize points based on the sampling results.  so, I haven't tried to add points by their coordinates.  When I have some time, I'lll try & let you know what happens.
    TdH
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    Please use plain text.
    Valued Contributor
    05-05-2012 08:01 AM in reply to: thepworth
    I was finally able to connect to the excel file and map the points.
    There was a duplicate point in the spreadsheet that I missed. Created another column with IDX(index) and everything works now.
    Thanks for your input.
    C
